Hexnode location map showing Arabic labels instead of English on Windows deviceSolved
5 months ago Jun 29, 2026
The location map for a Windows device is showing place names and map labels in Arabic. We need the map to display in English because the team cannot read the current labels. Is there a setting in Hexnode to change the map language to English?
Hello @douglas ,
Hexnode uses OpenStreetMap as the default map provider. OpenStreetMap does not provide a language switch within Hexnode for changing map labels to English. The labels are rendered based on the map data available for that region and may appear in the local language.
As a workaround, the device locations can still be listed in English in the location sidebar where applicable. If English map labels are required directly on the map view, the recommended option is to integrate Google Maps with Hexnode. Google Maps integration may require additional billing or API configuration depending on your setup.
