Hi @harold,
You can use a PowerShell script to toggle Windows Location Services for applications, then deploy it to Windows devices through Hexnode.
Hexnode has a sample script documented here: https://www.hexnode.com/mobile-device-management/help/script-to-turn-on-off-location-services-for-apps-on-windows/
Recommended rollout approach:
- Run the script on a single test Windows device first.
- Confirm that Location Services are enabled at the Windows system level.
- Verify that Hexnode is able to collect location data from the device after the script is applied.
- Once the behavior is confirmed, deploy the script to the required Windows device group.
Testing on one device first is strongly recommended, especially if your environment has different Windows versions or privacy configurations.
