Deploy a custom APN .mobileconfig to iOS devices with HexnodeSolved
2 months ago Sep 23, 2026
I’m trying to push a private cellular APN to managed iOS tablets through Hexnode. The devices keep using the default carrier APN, but if I manually change the APN on the device, cellular connectivity works. I was advised to create a custom APN profile with iMazing Profile Editor and deploy it through Hexnode as a .mobileconfig file. The APN should have no username or password, use PAP authentication, and IPv4 only.
Has anyone done this successfully? I’m also unsure what to enter in the Identifier field in iMazing, and I can’t find an option called Deploy Custom Profile under Policies > iOS.
Hi @ruthg_ ,
You can deploy a custom APN payload to iOS devices by creating a .mobileconfig profile using iMazing Profile Editor and uploading it to Hexnode UEM via Deploy Custom Configurations.
Step 1: Create the .mobileconfig file in iMazing Profile Editor
  1. Open iMazing Profile Editor and create a new profile.
  2. Under General, configure:
    • Name: Custom APN Profile
    • Payload Scope: System
    • Identifier: Enter a unique reverse-DNS identifier (e.g., com.example.apn.private).
  3. Add the Cellular / APN payload.
  4. Configure the APN settings:
    • Access Point Name: <private-apn>
    • Username: Leave blank
    • Password: Leave blank
    • Authentication Type: PAP
    • Supported IP Versions: IPv4
  5. Save the profile as a .mobileconfig file.
Step 2: Deploy the profile via Hexnode UEM
  2. Go to Policies > New Policy (or select an existing policy).
  3. Navigate to iOS > Configurations > Deploy Custom Configurations.
  4. Click Configure and upload your .mobileconfig file.
  5. Move to Policy Targets to assign the policy to your target iOS devices or device groups.
  6. Click Save to apply the policy.
Once the policy is applied, verify whether the APN updates automatically on the device.
What about the Identifier field in iMazing? It marks it as required, but does it need to match anything specific from Hexnode or the carrier?
The Identifier does not need to match a carrier value or a Hexnode value. Apple requires configuration profiles to have a unique reverse-DNS identifier so iOS can distinguish one profile from another.
A generic format like the following is fine:
If you later create an updated version of the same APN profile, you can use a new identifier such as:
com.example.apn.private.v2
In many cases, iMazing may prefill the Identifier automatically when you create the profile. You can keep the generated value as long as it is unique and follows the reverse-DNS style.
