Delete Device GroupSolved
5 months ago May 27, 2026
We want to clean up our portal by deleting few old device groups, but I can’t see any direct option like Delete or Remove or anything similar. So how can I do that?
Thats feels odd. If there is no direct button, there might be a option inside Actions, have you checked that?
Hello everyone,
To delete device groups in the portal, please follow these steps:
  • Navigate to the Manage tab and select Device Groups.
  • Check the box next to the specific group or groups you wish to remove.
  • Click on the Actions dropdown menu at the top left.
  • Hover over Group & Domains and select Delete group.
A confirmation window will pop up to prevent accidental deletions, as removing a group automatically detaches its associated configurations from the member devices. To verify the action, type in the total number of groups you have selected to delete and click Yes.
Please reach out to us if you face any issues with this workflow or encounter any other difficulties.
