Can supervised iPads install iPadOS public or developer beta updates?Solved
4 hours ago Nov 09, 2026
Are supervised iPads allowed to install iPadOS beta versions, such as Developer Beta or Public Beta? I’m checking this for a supervised iPad deployment and want to know whether supervision blocks beta OS updates by default.
15 minutes ago Nov 09, 2026
Yes. Supervision by itself does not block iPadOS beta installation. By default, users can install available iPadOS updates on supervised iPads, including beta versions, if the device is eligible and the user has access to the required Apple beta enrollment path.
However, the final behavior can depend on the restrictions and OS update settings applied through MDM. For example, if your Hexnode policies defer software updates, restrict update visibility, or otherwise control OS update behavior, beta updates may not appear or may be delayed according to the configured policy.
For managed deployments, it is recommended to test beta versions on a small set of devices first before allowing them on production iPads.
