Best way to automate hardware replacements for dying batteries?Solved
5 months ago Apr 30, 2026
Hey everyone. I‘m trying to get ahead of our hardware lifecycle because waiting for laptop batteries to swell or completely die mid-shift is causing way too much downtime for us right now.
I know I can push custom scripts to get the battery health data (like cycle counts and max capacity), but manually reviewing logs for 500+ devices every week is an absolute nightmare and just not going to scale for my small team.
What’s the best way to fully automate this workflow in Hexnode? If a laptop battery drops below 75% health, I want to trigger a whole replacement process before the user even submits a ticket. How are y’all handling this kind of automation?
@laura123, you are completely right to want to avoid manual log reviews. Transitioning from reactive break-fix management to a proactive lifecycle strategy is exactly where UEM automation shines. You can absolutely streamline this workflow to eliminate emergency IT spending and minimize operational downtime.
Here is the tiered automation protocol we recommend implementing in Hexnode UEM:
1. Audit & Analysis (The Baseline)
First, define your OS-specific baselines. For example, a ruggedized Windows tablet might need replacing at 70% capacity, while an executive MacBook might trigger at 80%.
  • Schedule Scans: Set your battery health scripts to execute automatically on a weekly basis.
  • Delta Reporting: Configure Hexnode to generate a monthly Device Activity Report. You can easily filter this to highlight only the endpoints where the Maximum Capacity has dropped below your threshold (e.g., 75%) or exceeded a specific Cycle Count (e.g., 500 cycles).
2. Automation via Webhooks
You do not need to manually create replacement tickets. You can configure a Webhook in Hexnode to communicate directly with your ITSM platform (like Jira, or ServiceNow via the Service Graph Connector). When a device hits that critical End-of-Life (EOL) threshold, Hexnode can automatically trigger the creation of a hardware refresh ticket assigned directly to your helpdesk.
3. Hypercare & Mitigation
While the user waits for their new device to be provisioned (ideally via Apple ADE or Windows Autopilot for a zero-downtime swap), you need to protect the failing hardware from overheating or swelling.
  • Target Filters: Use Hexnode’s dynamic groups to automatically move the “At-Risk” device into a specific triage group.
  • Aggressive Power Policies: Deploy a specific “Battery Optimization” policy to this group. Enforce aggressive sleep timers and remote shutdowns to mitigate thermal risks.
  • User Communication: Utilize Hexnode’s native Broadcast Message feature to ping the user. Alert them that their battery is reaching EOL, advise them to back up local data, and inform them that a hardware swap is scheduled.
By setting these parameters up once, you turn unexpected hardware failures into a predictable, planned operational investment. Let us know if you need help configuring the webhooks or target filters!
