Automatically grant app permissions on Android kiosk devices in HexnodeSolved
1 month ago Oct 10, 2026
I’m setting up Android devices in kiosk mode and want the installed apps to have their permissions allowed automatically. The goal is to avoid users being prompted to manually allow permissions like location, camera, storage, etc., after the app opens in kiosk. What can I do?
Hi @ezekiel,
You can manage Android app runtime permissions from the Hexnode policy, provided the device meets the Android Enterprise requirements.
For kiosk devices, check the following:
  1. Open the associated policy in Hexnode UEM portal.
  2. Go to Android > Advanced Restrictions.
  3. Locate the App Runtime Permissions setting.
  4. Set the permission state to Grant.
  5. Save the policy and make sure it is associated with the target devices or device groups.
This setting is supported on Android Enterprise devices enrolled as Device Owner or Profile Owner, and the device should be running Android 10 or later. Runtime permissions cannot be managed through policy on earlier Android versions.
After saving the policy, sync the device and relaunch the app to verify whether the permission prompts are suppressed.
