Android tablet QR enrollment not loading or scanning as invalid in HexnodeSolved
1 month ago Oct 10, 2026
I’m trying to enroll Android tablets in Hexnode, but the QR code that usually appears for enrollment is not showing up. I tried closing the browser and logging back in, but the QR area still stays blank.
I also tried using the Android Enterprise QR code, but the tablet reads it as invalid. The Hexnode app is already installed on the device, and I’m trying to complete the registration from there. Is there another way to enroll the tablet if the QR code does not populate?
Hi @cameron,
If the Hexnode app is already installed on the Android tablet and you are completing enrollment through open enrollment, you do not necessarily need to scan the Android Enterprise QR code.
Try registering the device manually from the Hexnode app:
  1. Open the Hexnode app on the Android tablet.
  2. Choose the option to enter the server or portal name manually.
  3. Enter your Hexnode portal/server name, for example: <portal-name>.
  4. Continue with the enrollment prompts.
The Android Enterprise QR code is intended for Android Enterprise Device Owner enrollment, usually during initial device setup or after a factory reset, depending on the enrollment method. If the device is not being enrolled through the Android Enterprise Device Owner flow, scanning that QR code may show as invalid.
For the QR code not rendering in the portal, you can also try opening the portal in an incognito/private browser window or clearing the browser cache and cookies. However, manual server entry is the quickest workaround when enrolling through the installed Hexnode app.
