Android Enterprise Samsung device stuck on mandatory VPN activation in Hexnode for WorkSolved
6 months ago May 14, 2026
A Samsung Android Enterprise device enrolled successfully, but when opening the Hexnode for Work app it shows an admin-mandated VPN activation screen. The Activate button on the VPN prompt does not respond, so the app cannot be used. This is happening on a Samsung A-series device, while other enrolled Samsung devices are not showing the same prompt. Where is this mandatory VPN setting controlled? I checked the Android Enterprise enrollment settings and VPN was set to Auto Enable. Does that mean the device has to be enrolled again? Also, I do not see a Sync Device option under Actions for this device.
Hi @timo-liam,
This behavior usually happens when VPN activation is enforced through Android data restriction settings or the Android Enterprise enrollment configuration.
If VPN Auto Enable was configured as part of the enrollment profile and you want to modify the core enrollment behavior itself, re-enrollment may be required for devices that have already gone through that flow. However, if the immediate issue is the blocking VPN activation prompt inside the Hexnode for Work app, changing the global data restriction settings will often clear the prompt without needing to re-enroll the device.
To check and disable this in the Hexnode UEM portal:
  1. Go to Admin > General Settings > Data Restriction (Android).
  2. Review the following options:
    • Prompt to activate VPN
    • Prompt to activate VPN while in kiosk mode
  3. Disable the relevant prompt options if they are not required, and click Save.
Regarding the missing sync option, if the Sync Device action is not visible, simply try reopening the Hexnode for Work app on the device or wait a moment for the device to check in automatically. Once the updated data restriction setting is applied to the device, the mandatory VPN prompt should no longer block access to the app.
Eden Pierce
6 months ago May 17, 2026
Disabling the VPN prompt under Data Restriction worked perfectly.Thank you for the help, that sorted it out.
