Android blocks hexnode remote assist Accessibility permission with “restricted settings” messageSolved
8 months ago Mar 18, 2026
I’m trying to remote control an android interactive display using Hexnode remote assist, but the device won’t let me enable the Accessibility permission for the Remote assist app. It shows a message saying: “Restricted settings. For your security, this setting is currently unavailable.” Because of this, remote control is not working. Is there a way to enable the Accessibility option?
Hi @mees,
This message is actually triggered by Android’s native security framework (introduced in Android 13). If an app is installed outside of a traditional store flow or flagged by the OS as requiring restricted permissions, Android automatically blocks access to sensitive settings like Accessibility to protect the device.
Fortunately, you can manually override this block to allow Hexnode Remote Assist to function. Here are the steps:
  1. When the “Restricted settings” dialog appears, tap OK to dismiss it. (This step is necessary to trigger the override option).
  2. Open the Settings app on the Android device.
  3. Go to Apps and select the Hexnode Remote Assist app.
  4. On the App Info page, tap the three-dot menu (⋮) in the top-right corner.
  5. Select Allow restricted settings. (You may need to verify with the device PIN/passcode).
  6. Go back to your device’s Accessibility settings and enable the required permission for Hexnode Remote Assist.
Once the restricted settings are allowed and the accessibility permission is granted, your remote control sessions should work normally!
Please let me know if you do not see the three-dot menu or need further assistance.
Eden Pierce
