Why do supervised ABM iPads show “Leave Remote Management” in VPN & Device Management?Solved
5 months ago Jun 06, 2026
We have company-owned iPads enrolled through Apple Business Manager and managed with Hexnode. The devices show as supervised and managed, but under Settings > General > VPN & Device Management > MDM Profile, there is an option called “Leave Remote Management.” When selected, iOS warns that the device will erase all media, data, and settings before leaving management.
These are business-owned devices, so we do not want users to remove MDM management. Is this expected for supervised iPads enrolled through ABM? Is there a Hexnode or Apple Business setting to completely prevent users from removing remote management?
5 months ago Jun 08, 2026
This behavior can be expected if the iPads were added to Apple Business Manager manually using Apple Configurator. Apple applies a 30-day provisional period for manually added devices. During this provisional period, iOS may show the “Leave Remote Management” option even if the device is supervised and enrolled through Automated Device Enrollment.
This is enforced by Apple and is intended as a safeguard in case a personally owned device was added to an organization by mistake. After the 30-day provisional period ends, the option is removed automatically, provided the Automated Device Enrollment profile is configured to prevent MDM profile removal.
To verify the Hexnode configuration:
  1. Go to Enroll > Platform-Specific > iOS > Apple Business.
  2. Open the ADE configuration profile assigned to the devices.
  3. Make sure “Allow MDM Profile Removal” is disabled or unchecked.
  4. Ensure the profile is associated with the relevant devices in Apple Business Manager/Hexnode. If “Allow MDM Profile Removal” is disabled and the 30-day provisional period has passed, end users should not be able to remove the MDM profile from company-owned supervised iPads.
We’ve seen the same thing with iPads added through Apple Configurator. The button disappeared on its own after the provisional period. For devices purchased directly through an ABM-linked reseller, we didn’t see that option once the ADE profile was set to disallow MDM removal.
“Leave Remote Management” on supervised ABM iPads is usually seen during Apple’s 30-day provisional period for devices manually added to Apple Business. Hexnode cannot remove that Apple-imposed option during the provisional period. To prevent MDM removal after the period ends, use Automated Device Enrollment and keep “Allow MDM Profile Removal” disabled in the assigned ADE configuration profile.
