Where do I get the Find My Mac PIN and what is it used for?Solved
6 months ago May 07, 2026
Where do I get the Find My Mac PIN from to wipe a device? I just entered 123456 as the password and it worked… so now I’m confused, what’s the actual point of this PIN?
Replies (6)
Haha yeah, that’s normal. You don’t retrieve it from anywhere, you create that 6-digit PIN at the time of initiating the wipe.
Feels like a simple step, but it actually matters once the wipe kicks in.
Yep, especially on Intel-based Macs that don’t have Apple Silicon or a T2 security chip. Those don’t just wipe and reset, they apply a firmware (EFI) lock using that PIN.
Ohh okay… so what does that look like on the actual Mac?
Once the wipe command hits, the Mac reboots into a lock screen before macOS even loads. Then it asks for that same 6-digit PIN, in your case 123456, and you have to enter it on the device to move forward.
Yeah and this is where it gets serious. That PIN is basically the hardware-level unlock key. If you forget it or just typed something random and didn’t note it down, the Mac is firmware locked. You can’t bypass it with a reset or disk erase. Only way out is going to Apple with proof of purchase.
So yeah, best practice is to use a unique PIN for each wipe, save it somewhere safe, and make sure whoever’s handling the Mac knows it. That PIN is literally what gets the device back to life after the wipe.
