What Hexnode features are limited when managing iPhones without Apple Business Manager?Solved
1 month ago Oct 20, 2026
We’re looking at managing company-owned iPhones with Hexnode, but we may not be able to use Apple Business Manager right away. What features are limited if the devices are enrolled without ABM? Does that basically make the ownership model similar to BYOD, where the user can remove management?
Hi @isaiah,
Without Apple Business, iPhones and iPads cannot use Automated Device Enrollment, also known as ADE. If the device is enrolled directly using a browser enrollment link, it is treated as an unsupervised enrollment by default.
The main limitations are:
– The MDM profile can be removed by the user from device settings.
– Zero-touch deployment is not available.
– Setup Assistant screens cannot be skipped automatically during out-of-box setup.
– Silent app distribution using Apps and Books is not available in the same way as ABM-integrated deployments.
– Supervision-only controls are unavailable unless the device is supervised separately.
Features that usually require supervision include Single App Mode or kiosk mode, app hiding or stronger app restrictions, Remote Lost Mode, blocking factory reset, restricting App Store or AirDrop, account modification restrictions, web content filtering, Global HTTP Proxy, and OS update management.
So, if the device is only web-enrolled without Apple Business and without supervision, it behaves closer to a BYOD-style enrollment from a management-control perspective.
That makes sense. So if we don’t have ABM, there’s no way to fully control the device as corporate-owned? The removable MDM profile is the main concern for us.
Hi @isaiah,
You can still get corporate-level control without Apple Business by manually supervising the device using Apple Configurator on a Mac.
With Apple Configurator, the device is physically connected to the Mac and prepared as a supervised device. Once supervised, it can be enrolled into Hexnode with stronger management privileges, including making the MDM profile non-removable.
The trade-off is that this is not zero-touch. Each device must be manually prepared, so it is more practical for smaller deployments or cases where devices are available physically before being handed to users.
