Self Service menu missing in Hexnode UEM app on macOS for temporary admin rightsSolved
9 months ago Feb 08, 2026
Hi everyone. I have a macOS policy configured that allows our standard users to request temporary admin rights through the Self Service menu in the Hexnode UEM app. This works perfectly for almost everyone, but on one specific laptop, the Self Service menu is completely missing from the app, so the user cannot grant themselves temporary admin rights.
What usually causes this menu to disappear for just one device, and how can I bring it back?
Hello,
When the Self Service option for temporary admin rights is missing on a specific macOS device but works for others, the most common cause is that the device’s local account inventory has not properly synced with the Hexnode portal. The Self Service menu relies on accurately detecting the role of the currently logged-in user; if the portal has stale data regarding the local accounts on that machine, the menu may fail to render.
You can easily resolve this by forcing the portal to refresh the account list directly from the device. Here is the quick workflow:
  2. Navigate to the Manage tab and click on the affected macOS device to open its details page.
  3. Click on the Actions dropdown menu.
  4. Go to Local Accounts and select Sync Local Accounts.
This action forces the device to report its current local user account details back to Hexnode. Once the sync action successfully completes in your portal’s action history, ask the user to completely quit and reopen the Hexnode UEM app on their Mac. The Self Service menu should now reappear, allowing them to access temporary admin rights.
(Note: It is also worth verifying that the Hexnode UEM app on that specific Mac is fully up to date, as significantly older versions of the app do not support the Self Service feature).
I hope this helps get that user set up. If you find any more issues or need further assistance, feel free to reach out.
George,
