Save and Cancel buttons unresponsive when editing policiesSolved
9 months ago Mar 12, 2026
Hey everyone. I’m running into a frustrating UI glitch in the Hexnode portal today. When I am in the middle of editing an existing policy, the Save and Cancel buttons at the bottom become completely unresponsive. They seem to highlight when I hover over them right after the page loads, but clicking them does nothing. I’ve tried clearing my browser cache and local site data, but it didn’t fix the issue. Has anyone else experienced this UI freezing up specifically on the policy editor page?
Hello,
This specific behavior is almost always caused by a third-party browser extension injecting scripts into the page and interfering with the portal’s UI elements after the page finishes loading. Security extensions or password managers are the most common culprits, as they often attempt to hook into form fields.
To isolate this, please open your Hexnode portal in a private or incognito browsing window. Since most extensions are disabled by default in this mode, test the policy editor page there. If the Save and Cancel buttons function normally in the incognito window, the issue is definitively an extension conflict.
To resolve the issue in your primary session, return to your normal browser window and disable your extensions one by one, reloading the policy page each time. This will help you pinpoint exactly which extension is hijacking the buttons so you can disable it specifically for the Hexnode portal.
George,
