How do I make sure my registry edits actually land in the right spot?Solved
7 months ago May 08, 2026
I’m pushing a PowerShell script to update registry keys on my Windows fleet, but it’s acting weird. Hexnode says ‘Success,’ but when I check the device, the registry key hasn’t actually changed. It’s like the script is running in a ghost environment. How do I make sure my registry edits actually land in the right spot?
7 months ago May 09, 2026
Hi there! This is a very common hurdle when working with UEM (Unified Endpoint Management) agents.
The issue isn’t your script, it’s Windows Architecture Redirection. Most MDM agents run as 32-bit processes. When they launch PowerShell, they launch the 32-bit version. Because Windows wants to maintain compatibility, it automatically “redirects” any 32-bit attempt to modify HKLM:\SOFTWARE into a separate folder called WOW6432Node.
Your script “succeeds” because it did write to the registry, it just wrote to the 32-bit version of the path instead of the 64-bit one that your application is actually using.
To fix this, you need to tell your script to check if it’s running in a 32-bit session and, if so, restart itself in the native 64-bit environment.
Paste this code at the very beginning of your script:
This ensures that no matter how the MDM agent starts the process, your script will always pivot to the native 64-bit environment before making changes. For more detailed explanation please refer our documentation: https://www.hexnode.com/mobile-device-management/help/deploying-powershell-registry-fixes-windows/
