Samsung apps missing after Knox enrollmentSolved
7 months ago Apr 16, 2026
Hey folks, I’ve been enrolling Samsung devices with Knox and noticed the Calculator app doesn’t always show up after setup. Sometimes it’s there, sometimes it’s gone. Anyone else seen this?
Yeah, I’ve seen that before. In my case, Knox activation seemed to mess with which apps showed up. One time the Calculator was suppressed, another time it popped back in. Honestly, I couldn’t figure out a clear pattern.
7 months ago Apr 17, 2026
Maybe, could it be related to the way system apps are enabled during enrollment? Could be that samsung doesn’t treat calculator as a system app in that mode. Just guessing though.
Hello everyone,
Apps like Calculator aren’t considered system apps, and they typically install only after completing device setup. These apps do not appear when enrolling as device owner through Knox, which is why the Calculator may be missing after enrollment.
You can install the Samsung Calculator as a store app from the Hexnode UEM portal using the Install Application action.
Please try it out and let us know how it goes.
