No Exceptions? Policy Targets Beg to Differ!Solved
5 months ago Jun 15, 2026
Hello,
We are thrilled to introduce a new enhancement to our policy deployment workflow! Administrators can now effortlessly manage policy exceptions and fine-tune your targeting with our brand-new Exclusion subtabs.
Managing complex group hierarchies just got a whole lot simpler. Instead of restructuring your Active Directory or creating complicated workarounds just to handle a few edge cases, you can now seamlessly filter out specific targets directly at the policy association level. The system ensures that your specific exclusions always take priority over broad inclusions.
To give you precise control, you can now refine your policy scope using:
  • Excluded OUs: Instantly omit entire Organizational Units from a broader policy deployment.
  • Excluded Users: Pinpoint specific individuals to safely bypass certain configurations or restrictions.
  • Excluded Devices: Selectively leave out individual hardware from a mass rollout, perfect for testing or special-use scenarios.
Whether you need to exclude a single device from a strict compliance rule, or keep an entire department out of a new app update, this feature allows you to deploy policies with absolute precision, hitting exactly who you need to, and nobody else.
We can’t wait for you to experience this new level of flexibility. Please do check it out and let us know your thoughts—share them right here in Hexnode Connect!
George,
Hexnode Connect
