Missing apps compliance status even though apps appear installedSolved
2 months ago Jun 26, 2026
Some of our managed tablets are showing a compliance issue for missing apps. The confusing part is that the same apps are visible under the Installed Apps tab for the device. Is there a way to refresh this status, and why does it not update immediately?
Hi @josiah,
The missing apps compliance status can remain outdated if the app inventory on the device has not been refreshed recently. Even if the app appears under Installed Apps, the compliance status may update only after the next app scan.
To refresh it immediately:
  1. Go to Manage, and open the affected device.
  2. Click Actions, and search for and run Scan for apps.
  3. After the scan completes successfully, check the compliance status again.
The status should update based on the latest app inventory collected from the device.
