A brand new Manage experience: Custom views and faster navigation are here!Solved
2 months ago Sep 22, 2026
Managing your devices just got a major visual upgrade! The Manage tab in your Hexnode UEM portal has a brand-new look built for speed and flexibility. We streamlined the interface so you can navigate your fleet faster and organize your daily workspace perfectly.
  • Expanded Endpoint Filters: When viewing your main list of devices, you will now see a much wider set of filtering options. You can easily sort your endpoints using specific details, including Compliance, Encryption Status, Supervised state, Enrollment Type, and many more.
  • Saved Custom Views: Tired of selecting the exact same filters every single day? You can now use the new Save As button to lock in your specific filter setup as a Custom View. These saved views appear directly in the side panel, giving you instant one click access to the exact information you monitor the most.
  • Customisable Sidebars: You can now personalize your sub-tab view inside the individual device details page. By clicking on the Customise Sidebar option, you can reorder and hide specific tabs. This allows you to arrange the layout, so the tabs you use most often are always front and center.
This fresh interface is ready for you to explore right now in the Manage tab.
And the best part? This visual revamp is just the beginning. Stay tuned, because we have even more exciting workflow enhancements rolling out to this section very soon!
7 days ago Nov 05, 2026
I like the Saved views filter.  However, it is horribly lacking.  For example, I have lots of iPad tablets, but I want to filter those tablets based on a Department Name, or an asset tag name.  Currently, I can set a view to see all tablets.  Please add more column definitions for filtering on different saved views.
Hi @amorris,
Thanks for the feedback! Advanced filtering criteria, including the ability to filter by department and asset tags, are already on our product roadmap and will be rolled out in an upcoming update.
