A Smarter Way to Automate Just LandedSolved
4 weeks ago Sep 22, 2026
Hexnode UEM has revamped the Automate tab triggers, introducing a scalable design that accommodates new and existing triggers. This enhancement categorizes triggers for easier discovery, resolves user confusion around deployment scheduling, and introduces new triggers to enable dynamic workflows and conditional automation.
What’s New
The Automate tab now follows a trigger-first rule creation flow and features a redesigned, categorized trigger selection interface, making it faster to build reliable, scalable automation rules.
Key Capabilities
Rules are now built the natural way, you’ll select your Trigger first, then define the resulting Action, instead of the earlier Action-first flow.
The trigger selection interface has been redesigned into clear, logical categories, moving away from the cluttered radio-button layout, making it much easier to find the right trigger as the list keeps growing.
New Triggers Added
Deployment
    • On Device Enrollment
    • On Device Re-Enrollment
SIM
    • On SIM Insertion
    • On SIM Removal
    • On SIM Swapped
Compliance
    • On Device Compliance
    • On Device Non-Compliance
    • On Location Compliance
    • On Location Non-Compliance
Inactivity
    • On Device Inactive
    • Device Inactive for Specific Time
Battery
    • Battery Capacity
    • Battery Temperature
    • Battery Status
Applications
    • Wi-Fi Data Usage Apps
    • Mobile Data Usage Apps
    • Total Data Usage Apps
    • Apps Installed
    • Missing Apps
    • App Version Match Status
    • App Version Mismatch Status
Device
    • Total Data Usage
    • Device Storage Capacity
Kiosk
    • Kiosk Activated
    • Kiosk Exited Device
Agent Permission
    • Permissions of agents
Group Membership
    • Added into Device Groups
    • Removed from Device Groups
Geofence
    • Device Within Geofence
    • Device Outside Geofence
Ready, set, and automate smarter with Hexnode UEM!
