Migrating macOS devices from another MDM solution can involve more than just transferring device management. Administrators often need to identify vendor-specific API endpoints, understand authentication protocols, and configure disenrollment workflows manually.
With Genie AI Discovery, Hexnode UEM simplifies this process by automatically researching public API documentation and mapping the technical requirements for device disenrollment. This turns a traditionally manual and error-prone migration step into a guided experience.
What’s new?
The Genie AI Discovery wizard organizes the configuration process into three stages:
- Source Discovery: Identify the existing MDM solution from which macOS devices are being migrated.
- Technical Mapping: Let Genie discover and populate the required API configurations. Administrators can review the generated mappings, make manual adjustments through API entry, or upload local shell scripts before validating the configuration.
- Test Connection: Once the technical mapping is complete, Hexnode UEM attempts to establish a connection with the source platform using the provided configuration.
With automated API discovery, macOS migration becomes a more transparent and manageable process. Spend less time navigating vendor documentation and more time getting devices ready for Hexnode UEM!
