Performing routine device management tasks often means navigating through different sections of the Hexnode UEM console. The new Quick Actions palette brings frequently used actions together in the top navigation bar, making them accessible from a single place.
What’s New?
Quick Access to Actions: Launch workflows such as adding a web app, creating a device policy, or setting up an automation directly from the Quick Actions palette. You can also initiate device commands, such as powering off a device, from the same interface.
Customize Your Quick Actions Palette: Add or remove actions to configure your quick-access list. You can select up to 8 actions and review your selection in the Preview panel before saving.
Browse 68 Available Actions: Browse and search through a catalog of 68 actions available in the Customize window, organized into categories, including General, Scanning and Monitoring, Device Control, Security, Applications, Updates, and more.
To get started, click the Quick Actions icon in the top navigation bar of your Hexnode UEM console. Select Customize to browse the available actions and configure your palette.
Lara Welsh
