Hi @akemi ,
On iOS and iPadOS, MDM solutions cannot remotely enable Location Services or grant location permission to an app if it was never allowed on the device. This is restricted by Apple for privacy reasons.
If location access was never granted to the Hexnode UEM app, regular app-based location tracking will not return the iPad’s location.
There is one exception for supervised devices: if the iPad is supervised, you can use Lost Mode from the Hexnode UEM portal.
Go to:
Manage > Devices > select the iPad > Actions > Security > Enable Lost Mode
When Lost Mode is enabled on a supervised iPad, iPadOS can retrieve the device location even if the Hexnode UEM app was not previously granted location permission. However, Lost Mode is intended only for lost devices and should not be used for routine or continuous tracking.
To check whether the iPad is supervised:
Manage > Devices > select the device > Device Summary > Hardware Info > Supervised
If Supervised is listed as On, Lost Mode can be used. If the iPad is unsupervised and location permission was never allowed, there is no remote method to retrieve its location through Hexnode UEM.
