iPadOS blocklist for supervised iPadsSolved
5 months ago Jun 08, 2026
I’m setting up our first supervised iPads in Hexnode and need to block some apps. I found the iOS Blocklist/Allowlist policy, but I’m not sure how native iPadOS apps are categorized. Are built-in Apple apps considered system apps?
Hi @ruthg_,
Welcome to the Hexnode community!
To block apps on supervised iPads using Hexnode, you can configure an app blocklist policy:
  1. On the Hexnode UEM portal, go to Policies and create a new policy or edit an existing one.
  2. Navigate to iOS > App Management > Blocklist/Allowlist.
  3. Click Configure and select Blocklist.
  4. Add the apps or app groups that should be blocked.
  5. Associate the policy with the target iPads and save it.
On supervised iPads, apps added to the blocklist are hidden from the Home Screen and cannot be opened. Native Apple apps are treated as system apps. However, not every system app can be hidden or blocked through MDM.
5 months ago Jun 09, 2026
That explains part of it. I can see some built-in apps, but the Phone app is missing from the blocklist picker. I was hoping to hide it since these iPads are not meant to be used for calling.
Hi @ruthg_,
The Phone app is not available in the blocklist because Apple restricts certain core system apps from being hidden, disabled, or blocklisted through the MDM framework.
This behavior is enforced at the iPadOS level. MDM vendors, including Hexnode, can only manage app restrictions that Apple exposes through supported MDM controls. As a result, apps such as Phone and Settings are filtered out and cannot be blocked using the standard blocklist policy.
