iPad compliance shows Data Protection or application security warning in HexnodeSolved
5 months ago Jun 23, 2026
One of our supervised iPads briefly showed a compliance warning under the Security section for Applications in Hexnode. There is no kiosk policy applied to the device. Reapplying the assigned policy made the application compliance status turn green, but I was still unsure about the Data Protection/encryption item. The iPad already has a passcode set. Where is the SSD/internal storage encryption setting configured in an iOS policy?
For iPads, internal storage encryption is handled by Apple at the hardware and OS level. There is no separate Hexnode policy option to manually enable SSD or internal storage encryption on iPadOS. To enforce Data Protection on an iPad, ensure that a passcode is required on the device. When a passcode is set, iPadOS uses it as part of the cryptographic protection for device data. In Hexnode, this is typically managed by applying a passcode policy to the device. If the compliance state does not update immediately after the requirement is met, reapplying or syncing the policy can refresh the compliance status.
That makes sense. So for iPads, there is no separate “enable encryption” checkbox like we might expect on a desktop device. The passcode requirement is what satisfies Data Protection?
Correct. On iPadOS, encryption is built in by default, and Data Protection becomes effective when a passcode is configured. From a compliance perspective, make sure the device has a passcode and that the Hexnode passcode policy is applied successfully.
For the earlier application compliance warning, reapplying the policy can help if the device had not reported the latest compliance state yet.
5 months ago Jun 24, 2026
Reapplying the policy refreshed the app compliance status, and after confirming the passcode was enabled, the Data Protection item also showed compliant. No separate SSD encryption policy was needed.
