Hello @alice_grey ,
For VPP app deployment delays on iOS, first confirm that Hexnode UEM has the latest VPP license information from Apple Business.
Recommended checks:
- Go to Admin > Apple Business/School Manager > Apple VPP in the Hexnode UEM portal.
- Confirm that the Apple VPP account is active and not expired.
- Click Sync to manually sync the latest apps and licenses from Apple Business.
- Go to the Apps tab and search for the affected app.
- Confirm that the License Type shows VPP.
- Verify that enough VPP licenses are available for the target devices.
- Re-initiate installation on the affected devices.
For immediate deployments, avoid waiting for the normal background policy sync. Go to Manage > Endpoints > [select the device] > Actions > Install application, choose the VPP app, and push it directly. You can also run the Scan Device action to make the device check in and process pending commands sooner.
The overnight compliance change likely happened because the VPP sync/license allocation and device check-in eventually completed in the background. Using manual VPP sync, direct Install Application, and Scan Device helps reduce that wait when the deployment is urgent.
