iOS device stuck on Activation Lock screen after remote wipeSolved
7 months ago Mar 12, 2026
Hi everyone. I recently performed a remote wipe on one of our supervised iOS devices to prepare it for a new employee. Now, the device is completely stuck on the Activation Lock screen during the initial setup assistant. It appears that Activation Lock was still enabled by the previous user prior to the wipe.
Does this mean we should always be turning off Activation Lock before wiping a device? I also noticed there is a Clear Activation Lock option when initiating the wipe, but checking that box threw an error in this specific instance. How can I get past this screen right now, and what is the best practice to avoid this deployment roadblock in the future?
Hello,
If Activation Lock is still enabled on an iOS device at the moment it is wiped, the device will halt at the Activation Lock screen during the Setup Assistant. To proceed, the device requires either the original Apple ID and password associated with it, or for the lock to be removed via Apple’s management options.
As a best practice for device offboarding, we always recommend verifying and disabling Activation Lock before initiating a remote wipe. This guarantees a seamless, zero-touch setup process for the next user.
Regarding the Clear Activation Lock checkbox available during the wipe action: this feature is designed to send a bypass command to Apple to clear user-based Activation Locks (which usually happen when an employee signs in with a personal Apple ID and turns on Find My). If this remote action fails or throws an error, the lock remains intact on Apple’s servers, which is why the device is currently stuck.
To resolve your current situation and get past the setup screen, you should check the device’s status directly within your Apple Business Manager (ABM) portal. If the device is officially assigned to your organization, you can locate its record in ABM and manually turn off the Activation Lock from there. Once the lock is cleared on Apple’s end, simply restart the iPad, and it will be able to continue through the setup assistant normally.
George,
