How to verify geo-policy assignments using reports in HexnodeSolved
1 month ago Oct 19, 2026
I need to confirm that every device has the correct geo policies assigned in Hexnode. In our setup, each one should have exactly six geo policies applied no more and no less. Is there a report that shows this in bulk? I’m trying to avoid opening each device one by one.
Hello @mila_beck ,
You can verify this from the built-in policy reports in Hexnode UEM.
Go to Reports > Built-in Reports > Policy > Device Policies.
This report lists the policies assigned to devices. For each geo policy, check the value under the No. of Devices column. Clicking that number opens the list of devices where that policy is applied.
You can also export the results and compare the device lists for your six geo policies to confirm that the expected devices have all required policies applied.
