How to delete a technician in Hexnode UEM?Solved
4 weeks ago Oct 26, 2026
I’m a Super Admin and need to remove a technician from our Hexnode UEM portal. I went to the Technicians and Roles page and can see the technician listed, but I don’t see a clear delete button beside the name. Where is the option to delete the technician?
Hi @rob_mitch ,
To delete a technician, use the row action menu on the Technicians and Roles page:
  1. Go to Admin > Technicians and Roles.
  2. Find the technician you want to remove.
  3. Click the three vertical dots (⋮) on the far right side of that technician’s row.
  4. Select Delete Technician from the dropdown menu.
  5. Confirm the deletion when prompted.
After confirmation, the technician is removed from the portal and loses access to the account.
