How to update MFA for technicians in Hexnode UEMSolved
1 month ago Oct 20, 2026
I’m trying to update the MFA/authentication method used by technicians in Hexnode UEM. I can see the Technicians and Roles section, but I’m not sure whether the change should be made on the technician account directly or through a profile. What’s the correct way to update MFA for technicians?
Hello @im_dany ,
You can update the MFA method for technicians through technician profiles.
Steps:
  1. Go to Admin > Technicians and Roles.
  2. Open the Profiles section.
  3. Select the technician profile you want to update.
  4. Click Edit.
  5. Update the authentication or MFA method configured for that profile.
  6. Save the profile changes.
  7. Go back to Technicians and Roles.
  8. Open the required technician account.
  9. Assign the updated profile to the technician, if it is not already assigned.
  10. Click Save.
The technician will then use the authentication method configured in the assigned profile.
