How can I find audit logs for a deleted user in HexnodeSolved
5 months ago Jun 25, 2026
Is there a way to check logs for a deleted user in Hexnode? I need to find the timestamp of the last relevant activity or deletion event for audit purposes, but I’m not sure where deleted user activity is recorded.
Hello @ace_98 ,
You can check this from the Audit Reports in Hexnode UEM.
Go to Reports > Built-in reports > Audit > Audit history, then apply the following:
  1. Open Filter.
  2. Set Created time to All.
  3. Use the search bar to search for “Technician deleted”.
This should display the relevant deletion action along with the timestamp, which can be used for audit verification.
Regrads,
