The Add Role option should normally appear under Admin > Technician and Roles > Roles when custom technician roles are available for the portal.
If the Roles tab is visible but the Add Role button is missing, it is usually not a navigation issue. Custom technician role creation is available only on the Ultimate and Ultra plans. On plans where custom roles are not included, technicians can still be added, but they must be assigned one of the default roles available in the portal.
So, in this case, you can either:
- Add the technician using an existing default role from Admin > Technician and Roles > Technicians.
- Upgrade to a plan that supports custom technician roles if you need to define custom permissions.
