Drill Down from dashboard data to related configuration/objectSolved
Ideation
May 06, 2021
Having a dashboard rich with information is helpful. It would be very helpful to be able to click through links from the information displayed, in order to drill down to areas of interest. For example, Compliance Breakdown shows a percentage of Passwords Non-Compliant. Having a clickable link on the data could show us which objects are affected and we could take action.
Hi Eric,
The feature for an interactive dashboard where you can check the devices marked in a particular field, is a feature that is part of our roadmap.
We shall keep you in loop with the developments on the same.
Thomas Specter
