Do Hexnode App Library deployments to Android 14 need different firewall ports?Solved
1 week ago Nov 20, 2026
We are reviewing firewall rules for Android 14 devices managed through Hexnode. When pushing apps from the Hexnode App Library, does app deployment use a different URL or port than regular device policy communication? Trying to confirm whether a separate firewall exception is needed for app installs.
6 days ago Nov 23, 2026
Hexnode app deployments to Android devices do not require a separate port from device policy management. Both device management communication and app deployment instructions use standard TCP port 443 over HTTPS.
The part that may differ is where the app package is downloaded from:
  • Enterprise apps uploaded to the Hexnode App Library are downloaded through Hexnode storage/CDN endpoints.
  • Store apps may involve the relevant store or managed app distribution endpoints, depending on the app type and deployment method.
So, for firewall planning, allow HTTPS traffic on TCP 443 for Hexnode device management and make sure the required storage/CDN or store-related URLs are also reachable. Android 14 does not introduce a separate Hexnode port requirement for App Library deployments.
