Hello @_janet .
This can be verified by comparing the device status with the portal action records.
Check the following areas in the Hexnode UEM portal:
- Go to Manage and search for one of the affected devices.
- If the device is not visible under Manage, check Reports > Built-in Reports > Device > Disenrollment Pending Devices and Reports > Built-in Reports > Device > Disenrolled Devices.
- Open the Device Summary page for an affected device.
- Review Action History and the Activity Feed.
- Also review the portal audit history for any bulk or individual disenrollment action.
If a disenrollment command was initiated from the Hexnode UEM portal, it should be recorded in the device action history or audit history with the corresponding action and timestamp.
If the device still appears as Enrolled but Inactive, it usually means the device has not been removed from Hexnode but has stopped communicating with the portal. This can happen when the device is manually taken out of kiosk mode, when the MDM profile is removed locally, when the device is moved to another MDM, or when the device no longer checks in.
For devices that were manually exited from kiosk mode during an MDM migration, the user may perceive the device as disenrolled because kiosk restrictions are no longer active and the device stops reporting normally to Hexnode UEM.
