Can Hexnode track screen time or app usage duration on iPads?Solved
2 months ago Sep 17, 2026
Is there a way to generate a report in Hexnode that shows how long an iPad is actively used during the day? We want to understand the daily usage time of a shared iPad and ideally see how much time users spend in specific apps. I checked the reports section but couldn’t find anything like screen time or app usage duration for iPadOS.
Hexnode UEM cannot generate active screen time, app usage duration, or unlock count reports for iOS/iPadOS devices. Apple’s OS-level privacy restrictions prevent MDM solutions from remotely collecting these detailed usage metrics from iPhones and iPads.
These detailed device usage reports are available only for Android endpoints in Hexnode.
As an alternative for iPads, you can monitor network activity and data consumption to get an indirect view of device activity. To use this, deploy a Network Data Usage Management policy to the target iPads, then go to: Reports > Built-in Reports > Usage Insights > Data Usage.
This will not show how long the iPad screen was active or how long each app was open, but it can help you review data consumption trends for managed iPads.
So just to confirm, there’s no way to get a screen time-style report for iPads through Hexnode? We mainly wanted to know how long a shared iPad is being used each day.
That is correct. Hexnode cannot provide a screen time-style report or app usage duration report for iPads. This is a platform limitation enforced by Apple, so the same restriction applies to MDM providers in general. For iPadOS, the closest reporting option available through Hexnode is the Data Usage report, provided the Network Data Usage Management policy is applied. If the requirement is to measure exact active usage time or time spent inside an app, that data cannot be collected remotely through MDM on iPads.
