Can Hexnode Replace my RMM?Solved
8 months ago Mar 21, 2026
Hey everyone, our enterprise fleet has grown massively over the last year, spanning across different time zones and remote home-office setups. We are currently stuck in a reactive break-fix nightmare where our IT team only jumps in after a system fails or a user complains. On top of that, our current standalone RMM tool is causing massive alert fatigue for our technicians. Since we already use Hexnode for device management, I was wondering; can Hexnode actually replace our dedicated RMM tool? I’m specifically looking for a way to maintain system awareness and handle remote troubleshooting without constantly disrupting our users’ workflow. Has anyone successfully made this transition?
8 months ago Mar 22, 2026
Hey!
If you adopt their Silent-First troubleshooting strategy. Instead of jumping straight into remote control and interrupting the user, we heavily rely on Hexnode’s non-interactive background access. For our macOS, Linux, and Windows machines, we use the Live Terminal to run diagnostics and restart services entirely in the background. For our remote Android fleet, the File Explorer lets us retrieve logs or manage local storage silently. As for your alert fatigue, you need to check out the Incidents Tab. It groups related events; like multiple failed logins tied to a location change; into a single contextual incident rather than spamming your inbox with 20 separate emails. It completely changed how we proactively monitor device health!
8 months ago Mar 23, 2026
That Silent-First approach sounds good! Grouping the alerts contextually via the Incidents tab is a plus, too. But relying heavily on background tasks through the Live Terminal usually requires my Level-1 techs to be really proficient at writing complex Bash or PowerShell scripts, which isn’t always the case. Also, what happens when a background script just isn’t enough to fix the issue? How does the workflow transition from background diagnostics to actual hands-on troubleshooting within the Hexnode console?
7 months ago Mar 25, 2026
For the scripting hurdle, you should try to leverage Hexnode Genie. It’s an AI-driven automation assistant built into the platform. Your L1 techs don’t need to be PowerShell experts; they can just use natural language and ask it to “Create a script to clear cache on all macOS devices with less than 5GB available,” and the Genie generates the code. It can even be set up for auto-remediation! But always test the script before executing it in bulk.
As for escalations, the workflow is actually smooth. If Level 1 background diagnostics don’t resolve the issue, you simply step up to Level 2: Guided Support. You use the Remote View feature to visually confirm the problem while the user drives, which is fantastic for educating them without taking over their mouse. If you still need deeper access to fix complex software issues or handle UAC prompts, you escalate to Level 3: full Remote Control for direct intervention. It keeps the whole progression under one pane of glass and ensures you only disrupt the user when absolutely necessary. Highly recommend testing it out in your environment!
