Can Hexnode policy configurations be exported to PDF?Solved
5 months ago Jun 16, 2026
Is there a way to export the details of a Hexnode policy into a PDF or similar document? We need to provide a copy of our policy configuration for a certificate/compliance-related application and would prefer not to manually copy and paste every setting from the policy pages.
Hi @haniel,
Hexnode currently does not include a native option to export policy configuration details directly to PDF from the policy creation or configuration pages. There is no built-in “Export to PDF” or print-ready policy layout available in the portal at this time.
If the requirement is to duplicate or preserve the policy configuration inside Hexnode, you can use the Clone option to create a copy of an existing policy and modify it as needed. However, cloning is only useful for replicating a policy within the portal and does not generate an external PDF or document.
For certificate applications or compliance documentation, the current limitation is that the policy details must be documented manually outside the portal. A native policy export option would be useful for this use case, and this has been noted as a product enhancement request.
