Bulk uninstall an app from all devices in a device groupSolved
4 months ago Jun 18, 2026
Is there a way to uninstall one app in bulk from all devices in a device group? I want to avoid opening each device separately and removing the app one by one.
Hi @wilma,
You can uninstall an app in bulk from all devices in a device group using a group-level action.
Go to Manage > Device Groups, open the required device group, then click Actions > Applications > Uninstall App. Select the app you want to remove and initiate the action.
Hexnode will send the uninstall command to the devices in that group. The app removal behavior may depend on the device platform, app type, and whether the app is managed through Hexnode.
