Block a specific Store apps on macOS using Hexnode blocklistSolved
3 months ago Aug 03, 2026
I’m trying to block a specific Store apps from being downloaded or used on our managed macOS laptops. I don’t want to block all app installations, just a few selected apps.
I went to App Management > Block/Allowlist > Add App, but it only showed local apps from enrolled devices. The app I want to block is not installed on any managed device right now, so it doesn’t appear in the list.
Is there a way to add a Store app to the macOS blocklist even if none of the devices currently have it installed?
Yes @maatthew. The local app list only displays applications that are already detected on enrolled devices. If the app is not installed on any managed device, it will not appear there automatically.
To block a specific Store app that is not currently installed:
  1. Go to Apps.
  2. Select + Add Apps.
  3. Choose Store Apps.
  4. Search for the required app and add it to the Hexnode app repository.
  5. Go to Policies > macOS > App Management > Blocklist/Allowlist.
  6. Open the Blocklist section and select Add App.
  7. Choose the app you added to the repository.
  8. Save the policy and associate it with the required devices, users, or groups.
Once the policy is applied, the selected app will be blocked from being installed or launched on the targeted macOS devices, while other applications remain unaffected.
Hi @isabel_lora, just to confirm, this approach is for blocking selected apps only, right? It doesn’t force a full allowlist setup where every other app gets blocked?
Hi @lucaas,
Yes, adding a specific app under the macOS blocklist blocks only that selected application for the policy targets. It does not block all other applications unless you configure an allowlist-only restriction separately.
For this use case, adding the Store app to the app repository and then selecting it in the blocklist is the appropriate method.
