Automate disable kiosk mode actionSolved
8 months ago Mar 12, 2026
Hi, we’ve been using kiosk mode on a bunch of our Android devices, mostly for single-app workflows. Right now, whenever we need to take a device out of kiosk (for troubleshooting or updates), we’re doing it manually. Is automating the disabling of kiosk mode actually a thing people rely on?
8 months ago Mar 13, 2026
We automated it for patching windows.
Our devices run in kiosk during business hours, but we temporarily exit kiosk mode at night, so system updates and app updates can run without restrictions. Once that’s done, the kiosk gets re-enabled.
8 months ago Mar 14, 2026
We took it a step further and tied it to conditions instead of schedules. Before this, we had to wait for someone to notice, then manually intervene. Now it’s almost instant.
8 months ago Mar 16, 2026
One thing to watch out for, don’t leave it open-ended. We made the mistake early on where kiosk mode was disabled via automation, but there was no guaranteed step to bring it back. A few devices stayed unlocked longer than intended.
Hi everyone,
Automating the Disable Kiosk Mode action is less about the action itself and more about when and why you trigger it. In most environments, it becomes part of a broader workflow rather than a standalone action.
For example, scheduled exits during maintenance windows help ensure updates and background processes aren’t blocked by kiosk restrictions. There’s also a lifecycle angle to this. During provisioning, migration, or reprovisioning, devices may need to briefly exit kiosk mode to complete setup tasks before being locked down again. Automating that transition removes manual gaps and keeps deployments consistent.
That said, control is important. Since kiosk mode defines the device’s locked state, automation should always be paired with clear guardrails, whether that’s time-bound execution, dependency on specific triggers, or automatic re-enablement after the task completes.
In short, it works best when it’s part of a closed loop: exit kiosk → perform action → return to kiosk.
