Android tablets in kiosk mode keep losing battery optimization permissionSolved
3 months ago Aug 17, 2026
Some of our Android tablets are locked in kiosk mode and run a tracking app. After a few weeks or months, the app’s battery setting gets changed back automatically, so the app stops working in the background. The only way we have been fixing it is by exiting kiosk mode on each tablet and enabling the battery permission again manually. This is happening across a large fleet, so doing it one tablet at a time is causing delays. We also noticed that remote view sometimes works, but remote control does not always respond when trying to interact with the tablet from the portal. Is there a way to keep the app’s battery permission allowed permanently from Hexnode, or stop Android from changing it later?
Android battery optimization behavior is controlled by the Android operating system and, in many cases, by the device manufacturer’s battery management layer.
If an app does not natively request persistent background execution or exemption from battery optimization, Android may move it back into an optimized/restricted state over time. Hexnode can help manage kiosk mode and app deployment, but it cannot force a third-party app to permanently retain background battery access if the app or OS does not support that behavior.
For this scenario, check the following:
  1. Confirm whether the app itself requests unrestricted background activity or battery optimization exemption during setup.
  2. If the app does not expose this permission request, the long-term fix usually needs to come from the app vendor, such as adding support for persistent background execution.
  3. If the device has OEM-specific battery controls, verify whether the app is allowed to run in the background under those Android battery settings.
  4. For affected devices already in kiosk mode, the practical workaround is to temporarily exit kiosk mode, re-enable the app’s battery/background setting, and return the device to kiosk mode.
For the remote control issue, if remote view works but input control does not respond intermittently, it is often related to browser session cache, network quality, or device connectivity. Try opening the Hexnode portal in an incognito/private browser window or clearing the browser cache before starting a new remote control session.
That matches what I’m seeing. The battery option is not something I can enable inside the app itself. It has to be changed from Android settings after leaving kiosk mode. So Hexnode can’t push that exact battery setting back automatically?
3 months ago Aug 18, 2026
Correct. If the setting is controlled by Android and the app does not request or maintain the required background permission, Hexnode cannot guarantee that Android will keep it enabled permanently. Hexnode policies can restrict or allow device behavior in kiosk mode, but Android’s battery optimization state for an individual app is still dependent on OS-level permission handling and the app’s own implementation. If the app is business-critical and must always run in the background, the recommended route is to have the app support Android’s background execution and battery optimization exemption requirements properly. For devices where this has already reverted, manual re-enabling may still be required unless the app or OEM provides a managed method to preserve that setting.
