Android kiosk mode only shows some apps after allowlisting WhatsAppSolved
1 month ago Oct 23, 2026
I’m setting up Android Enterprise devices in Device Owner mode with Hexnode. I restricted app installation and added WhatsApp as a required app, but WhatsApp stayed pending. The Play Store is not visible on the device either.
I’m also testing multi-app kiosk mode. After switching to kiosk, the kiosk home screen only shows a few apps like Gmail, Chrome, and Maps. I thought apps in the allowlist would appear there, but they don’t.
What is the right way to allow Play Store/WhatsApp, and make those apps visible in Android kiosk mode?
Replies (7)
Hello @ed_evans ,
When setting up app restrictions alongside kiosk mode, each behavior is controlled by a different policy setting:
  • Blocklist/Allowlist controls whether an app is permitted to be installed or used on the device.
  • Required Apps controls which apps Hexnode UEM installs automatically.
  • Multi App Kiosk controls which apps are visible and accessible on the kiosk home screen.
For WhatsApp to install through Managed Google Play, make sure WhatsApp is added under Policies > Android > App Management > Required Apps (and included in your allowlist if allowlisting is enabled).
If the Play Store is hidden or restricted, Managed Google Play app installations can remain pending. To allow it, navigate to Policies > Android > App Management > Blocklist/Allowlist, select Allowlist, and add Playstore (com.android.vending).
The Play Store does not need to be added under Required Apps since it is a built-in Google service on Android Enterprise devices it simply needs to be allowlisted when app restrictions are enforced.
1 month ago Oct 26, 2026
Adding Play Store to the allowlist fixed the installation part, and WhatsApp started installing. But, I’m still confused about kiosk mode. The app is allowed now, but it doesn’t appear on the kiosk home screen. Only the apps already added to the kiosk policy are showing.
That behavior is expected. In multi-app kiosk mode, Hexnode UEM only displays apps that are explicitly added to the multi-app kiosk configuration.
Adding an app to Blocklist/Allowlist only permits the app to run on the device,it does not automatically place the app on the kiosk launcher.
To display WhatsApp on the kiosk screen:
  1. Edit your policy and navigate to Kiosk Lockdown > Android Kiosk Lockdown > Multi App.
  2. Click Configure, click the + icon, and select Add app.
  3. Select WhatsApp, click Done, and save the policy.
The same applies to any other app that should be visible to the end user in kiosk mode.
Can built-in apps like Phone and Messages be used the same way? The devices already have their own dialer and messaging apps.
Yes. Built-in apps such as Phone and Messages can be used in multi app kiosk mode by adding them under Policies > Kiosk Lockdown > Android Kiosk Lockdown > Multi App (and ensuring they are also included in your Allowlist if allowlisting is active).
When adding them under multi app kiosk, enable the System App filter in the app selection window. Since the device manufacturers often use custom package names for their dialer and messaging apps, make sure you select the exact system app package used on your device model.
1 month ago Oct 27, 2026
What about Bluetooth? I only want users to configure Bluetooth, not access all device settings or transfer data freely in kiosk.
In Android kiosk mode, Bluetooth access can be controlled from the Peripheral settings policy:
  1. Edit your kiosk policy and navigate to Kiosk Lockdown > Android Kiosk Lockdown > Peripheral Settings and click Configure.
  2. Under the Network section, enable Allow users to turn Bluetooth on/off and save the policy.
Note that the Peripheral Settings only lets users toggle Bluetooth on or off, it does not expose full Bluetooth pairing settings or provide granular control over specific Bluetooth device connections or data transfers from within the kiosk configuration.
