On a few Windows devices, Hexnode remote actions and scripts stopped working properly. Restarting the device did not fix it, and the Hexnode Agent/Updater seemed to be the likely cause. After that, vulnerability scan results also showed failed/missing items.
I was trying to remediate the vulnerabilities directly, but I’m not sure if I should be pushing the vulnerability ID or applying patches. The applicable patches were installed on the device, but the Hexnode portal did not immediately reflect the updated status.
What is the correct way to restore management on these Windows devices and clear the vulnerability/patch status in Hexnode?
