Windows agent asks for username/password and UAC during silent enrollmentSolved
1 month ago Oct 21, 2026
I’m enrolling Windows devices with the Hexnode agent and expected the installation to be silent. When I tried it, the installer asked for a username/password and then showed a UAC prompt. The device did enroll afterward, but I’m not sure if this is the expected deployment method. How do I make the Windows enrollment fully silent without the authentication prompt or UAC interruption?
Hello @sutton ,
The username and password prompt appears when the Windows enrollment profile is configured for authenticated enrollment.
To remove the Hexnode username/password prompt during enrollment:
  1. Go to Enroll > Windows PCs and Tablets.
  2. Open Enrollment profiles.
  3. Select the default enrollment profile, or the profile used for the deployment.
  4. Go to User Authentication.
  5. Set it to No authentication.
After this change, Windows devices using that enrollment profile should not ask for Hexnode user credentials during enrollment.
For a fully silent enrollment that avoids the UAC prompt, generate a custom MSI from the migration workflow:
  1. Go to Enroll > Migrate to Hexnode.
  2. Select Generate a configuration file.
  3. Enable the option to migrate silently.
  4. Generate a custom MSI.
  5. Deploy or install the generated MSI on the Windows device.
This custom MSI is intended for silent migration/enrollment and should enroll the device without requiring the interactive prompts seen with the standard installer flow.
