Will SCEP handle certificate renewals automatically on iOS?Solved
5 months ago May 07, 2026
We’re looking into SCEP for our iPhones, but I’m a bit worried about the long term. What happens when these certificates expire? I really don’t want to be stuck manually re-pushing policies to hundreds of devices every time a certificate hits its end date.
I too have a concern, what happens to the certificate on a BYOD device after that employee left the company?
I don’t think you need to worry about the certificate renewals. I think the device and server will combine to renew the certificate. But I’m not sure about the certificate network access.
Hello everyone, thanks for bringing this up.
Beyond the initial deployment, SCEP provides a robust framework for managing the entire lifecycle of a certificate and maintaining strict network access control.
Here is how this strengthens your management process:
  • Automated Lifecycle Management: SCEP eliminates the need for manual tracking or re-enrollment. The protocol allows devices to automatically negotiate renewals with your Certificate Authority, ensuring uninterrupted connectivity without administrative oversight.
  • Dynamic Access Control: Since these certificates act as the primary authentication factor for your Wi-Fi or VPN, you gain immediate control over network entry. If a device is disenrolled or becomes non-compliant, the certificate is effectively revoked, securing your corporate environment instantly.
This approach ensures your credentials remain current, and your network stays protected with minimal manual effort.
To understand the strategic advantages of managing certificate lifecycles via SCEP, please refer to our guide on Bulk iOS SCEP Certificate Automation.
