Why does Hexnode say “ Success” but my registry change never applied?Solved
5 months ago May 18, 2026
So yesterday was a rough one. Deployed a PowerShell registry script through Hexnode, it showed “Success” on every device, but the actual policy change never applied anywhere. Spent hours trying to figure out what went wrong with zero error logs to go on. Clearly I’m missing something fundamental — what are the best practices I should be following when writing scripts for Hexnode deployments?
Thanks for raising this question. Some of the best practices you may consider are the following:
1. Always write output at every step
Since Hexnode runs your script silently in the background, you have zero visibility unless you explicitly log what’s happening. Add a log line at every logical step — when a path is found, when a key is written, when something fails. Hexnode captures all of this, and you can read it anytime by going to Action History → Show Output. That alone would have saved you those 3 hours.
2. Check before you create
Before creating a registry key, always check whether it already exists first. This keeps your script idempotent, meaning it is safe to run multiple times on the same machine without accidentally overwriting things or throwing unexpected errors.
3. Wrap everything in error handling
Never let your registry write commands run bare. Make sure that if something goes wrong; a permission issue, a locked key, anything, the script fails gracefully and logs a clear message instead of just hanging silently.
4. Keep everything silent
Make sure none of your commands produce interactive prompts or pop-ups. Since the script runs in the background, any UI element will cause it to freeze and eventually get killed by Hexnode’s timeout.
Follow these four habits and you will always know exactly what your script did, on every machine, without ever having to remote in and guess.
