Which Hexnode plan supports iPads with Apple DEP?Solved
6 months ago May 21, 2026
What’s the lowest plan that supports Apple iPads?
Replies (6)
Hi @maevee! That depends a bit on what you’re planning to do with the iPads after enrollment. Are you just looking for basic management, or do you need features like automated enrollment, app deployment, restrictions, etc.?
We definitely need the Apple DEP process for enrollment.
Got it. If Apple DEP (now called Automated Device Enrollment via Apple Business) is the requirement, then you’ll need at least the Pro plan.
So the lower plans won’t support DEP at all?
Right. The lower tiers handle basic device management, but Automated Device Enrollment (ADE) requires more advanced capabilities like zero-touch enrollment, supervision, and policy enforcement during setup — those are included starting from the Pro plan.
Okay! We mainly want devices to auto-enroll and get configured out of the box. Thanks Isabel.
