Where to find Hexnode portal subdomain and API key for an integrationSolved
3 months ago Aug 09, 2026
I’m setting up an external integration with Hexnode and the developer team asked for two values: the Hexnode portal subdomain and the API key. I can see the Hexnode console, but I’m not sure which value should be used as the subdomain or where the API key is generated from. Is the subdomain the full portal URL or just part of it?
You can retrieve the required integration details from the Hexnode portal.
For the API key:
2. Go to Admin > API.
3. Copy the API key shown there and use it in your integration as required.
Make sure the API key is handled securely and shared only with the application or service that requires it.
